Help! Hard Shifting
Jack64
Massachusetts
1964 coupe
'64 has 502 miles since frame off restoration.
Engine, rear, transmission re-built.
New clutch.
Hard shifting, especially into reverse.
Must depress pedal to floor.
Clutch seems to not fully release.
Clutch adjustment is at the END of the threaded rod
Condition worsens after driving for 30-45 minutes.
Does this sound like incorrect/improperly installed throw out bearing?
(Still working on brake light problem. To update)
Thanks any input
Tom Bryant
Administrator
Edgerton, Ohio, United States
1959 black 270hp (9/2/69) 1981 Beige L81(10/20/80)
That would be my first guess. pull the inspection cover off to check for the short bearing and the correct clutch fork.
Tom
Jack64
Massachusetts
1964 coupe
Thanks, Tom.
Heading to shop Tuesday.
Battling torn up knee so unable to work on.
Will update
LLC5
Wa.
98 black 6spd convert.
Incorrect or mismatched parts, improperly surfaced flywheel, friction plate in backwards, are all suspects if there is no adjustment left.
