allcoupedup
A LUK clutch RepSet pressure plate and clutch were installed about 500 miles ago and pulled today. I pulled it because there was extreme judder when disengaging the clutch - had this symptom since mile 1. I believe the flywheel is original and it was resurfaced in a flywheel machine before the install. Everything was clean as a whistle before installation.
Flywheel obviously got hot and has heat cracks - but only on the inner half of the disc/flywheel contact surface.
Clutch disc shows wear on the inner half of the contact surface:
Here's the interesting part.... the pressure plate and flywheel exhibit matched heat spots. I marked the flywheel/pressureplate relationship and have marked the matching heat spots in the picure below:
Any ideas? I can't see anything obvious on the disc or the pressure plate and need some facts before I try to get a replacement set from LUK. Could the flywheel have been cut wrong? Could I have broken something during the installation?
thanks in advance
Brian
thanks in advance
Brian
ad
