meridian6
C4 LT1 6-Speed manual. Just started grinding noise when clutch pushed to floor. If you ease off, grinding noise goes away. Shifts in all gears fine, no slipping or hard shifting and no noise. Just the grind noise if clutch pushed to floor (of course this happens when not extremely careful).
OK
Took down transmission and clutch cover and see that fork is just touching pressure plate (grinding) when hydralic clutch is pushed all the way to floor.
Is something wrong with slave (allowing too much push)? or is maybe the clutch disc is just wore out? Fork and Ball stud look OK. I'm a little afraid to pull pressure plate to look at disc!
ANY IDEAS???????
OK
ANY IDEAS???????
