Explosive
New member
I recently had a leaking Slave Cylinder, thus very hard to shift gears. Had slav changed and also replaced Master Cylinder. Gears shifted great after the change, but found it took more pressure to engage the clutch and longer for the clutch to disengage. Wondering if there is a Hydraulic Hose that is too soft as hose should be hard enough so it doesn't expand under pressure. Any INFO in regards to this problem is much appreciated. Thanks
