- Joined
- Mar 27, 2003
- Messages
- 3,703
- Location
- Mustang, OK
- Corvette
- '13 427 60th vert - '25 Eray Hysteria Purple - CTS V Wagon(4-door Vette)
Dealer replaced the clutch, pressure plate, master and slave cylinders. Now my clutch is working again. Good thing since I plan to drive it on the Caravan at the end of the month.
Tech said there was oil/fluid on the clutch material. Clutch fluid level was a little low for only 17,000 miles, so it was probably leaking on the clutch. Tech did point out that after replacing the clutch and the pressure, the clutch fluid system would not bleed properly and that prompted the replacement of the cylinders. I wonder if the TSB covered that?
