- Moderator
- #1
The Registry received an email from a New Member concerning readouts on his OTC 2000 Scanner. I've stated before my forte is NOT engines or engine related items, Sooo here is the Email as received. I'll try to get this newest Registry Member here to add comments, or I will make sure he receives any response's
TIA
Bud
Steve said:I am using a otc 2000 scanner to go through information. i am not flagging any codes. I wanted to know if you have the ranges for the following:
coolant temperture?
o2 volts?
02 cross counts?
mixture control dwell?
throttle position sensor volts?
vechicle speed - if i am doing 25 the otc scanner is reading 35 ???
map volts?
these are the basics i can test for.
here is my problem when i am driving the car over time and the tcc kicks in the car tends to bog down ( may be wrong termology) trying to find out what is causing this problem??
TIA
Bud
