DAVZKAR
Has anyone used 40 below in their car?
RodsnRides said:I also use Water Wetter (Red Line product). I have had good results with it. It's worth at least 10 degrees in my cars (early 70's Chevys).
I have not used 40 Below, have seen it but no opinion,
Rick
the biggest cause of overheating on older orignal rads is not the scale inside the rad tubes BUT the fact the pressed in fins between the tubes on the outside of the rad loses thermal contact and does not draw the heat from the tubestyrel said:I've heard about water wetter for years and went to this pdf document to check it out:
http://www.redlineoil.com/whitePaper/17.pdf
One thing that concerned me was how WW with just water actually lowers the boiling point to 250° instead of the 265° you get with a 50/50 mix of water and glycol. So the tradeoff is that maybe your coolant will cool more quickly, but you'll also have a lower boiling point. I don't know about anyone else, but I'll stick with my good old 50/50 water/glycol to keep that extra 15° cushion, who knows when you'll need it. Also: "Sudden shutdown after very hard driving may cause boilover." Some of their claims are a real head-scratcher: "Doubles the wetting ability of water." Huh? "Reduces cylinder head temperatures." So does your cooling system if it's working properly. Sorry, but I'm not convinced that WW is all that effective, just my opinion, but read the link for yourself.
