mmorse
My water pump is leaking on my '08 LS3. Looks like it's coming out of the fitting on the top of the pump that the upper radiator hose attaches to. Can that fitting be replaced or does the entire pump need replacing? If so, is the fitting press fitted? I'm trying to avoid the hassle of taking it to the dealer. The 2 dealers around me have lousy service depts. I know from personal experience.
Also, when I removed the throttle body to get a better look at where the leak is, I noticed the inside of the intake manifold has a thin layer of oil on the entire inside surface. Is that normal?
