Torchy_vette
New member
I have an 84 c4 vette , I was wondering if I bypassed the fan relay will I lose any hp???
 or what? Do you have an overheating problem now?
 the fan motor works great ! But it just won't kick on at the desired temp any ideas?  Thanks again for the welcoming haha!!
 the fan motor works great ! But it just won't kick on at the desired temp any ideas?  Thanks again for the welcoming haha!! ad I've replaced the relay and still nothing it was a pre owned vette  I'm gonna replace the sensor ,the problem may lie in the wiring :ugh  Then if it doesn't work I'm going to bypass the relay
THANK YOU !! and yes the fan won't come on I've replaced the relay and still nothing .�� the fan motor works great ! But it just won't kick on at the desired temp any ideas? Thanks again for the welcoming haha!!
You can't wire the fan control wire from the ECM directly to the fans.
Your choices are:
1) Trouble shoot the cooling fan circuitry per the Service Manual then fix the problem
2) Wire the load side of the relay to a switch which can handle the current and control the fans manually.
