Welllllll...
So, we have properly set the clearance at 1/4 past slight friction on the bottom of the lobes (no sweat) and yes they do hit.
So pulled the heads (Donna loved that 65 ftlbs of torque!) and sure enough, the lifters are coming up with the pistons.
Now, you know that the valves are suppossed to lift a little early to account for good gas scavenging and swirl mixture and all that, BUT, these guys are way early.
Last time I had the cam gear off, there were no end markings on the cam. The lifters are HYD and still have a nice convex surface with no appearant wear. Obvious aftermarket replacement.
The pistons look like the original hightops (Maybe 10:1?) and the cylinders still have obvious crosshatch. Since the car WAS running the plugs nice and tan with no oil usage, I believe it is in good shape, though I am still suprised by the chain slack.
I agree with you that the lift is not the problem. I have new stock pushrods and they are the same as the old ones.
The pistons do have a tiny nick in them where they made contact. I know that stress of smacking valves can put in unseen stress cracks, so I am carefully evaluating them. I have seen piston explode at 6000 rpm from this sort of thing.
However, the valves aren't bent at all, so my guess is the stock pushrods were weak enough to really absorb the damage and thus the pistons are probably fine.
WHEW!:eek
Okay, tonight we'll finish disassembly and give another update tomorrow.
The saga continues!
Rick and Donna
