Mr. Chuck
- Joined
- Jan 19, 2005
- Messages
- 230
- Location
- Southern California
- Corvette
- 1981 Two tone silver / dr grey
I thought I had posted this problem before, but can't seem to find it to up-date it, since I have now found and corrected the cause of the problem.
Problem: For several years have experienced a dimly lit alernator warning light.
Work done: Checked and/or replace Alternator / light wiring and connectors; without success. After input from dealer and other Vette Service shops; removed alternator, dis-assembled and check out varies electrical components (diode trio, rectifier, regulator, etc) Found diode trio had one open diode element. Replace diode trio and the problem is fixed.
Funtional analysis: The three diodes provide rectified DC voltage to one side of the warning light, while the other side of the warning light receives output DC voltage from the alternator. When the two equal each other light remains dark. In this case the diode trio output was low since one or more of the diode elements had failed. The use of an volt meter set for AC Voltage would have shown some level of AC / varing DC voltage at the alternator #1 pin, the Brown wire on my 81 vette to alternator housing. Hope this info may be helpful to someone out there!
