g-force junky
Active member
- Joined
 - Oct 2, 2003
- Messages
 - 34
- Location
 - wesleychapel, fl.
- Corvette
 - 1995 torch red lt1 automatic 1996 black cv z28
Ok, Ive researched all the vats threads  and need to know conclusively, if installing the bypass will work.
1. my security system arms..light goes solid
2. wth the system armed ,window down , unlocking door, from outside,opening door, will sound horn.
3. trying to start the car when armed ..will sound horn.
4. unarmed, open door security light flashes..place key in ignitionturn ..light goes solid.. wait for 3 to 4 minutes with key always in ignition. the system has had time to reset. turn key security light is out and it fires up.
5. key measure's ohm's for a code 14 on gm vats scale
6. cleaned area around column insert and key detents for grime that might impead reading.
7. will installing vats security bypass, keep me from having to wait 4 minutes for timeout sequence or is there something else afoot. ??? thanx cac for all the info on previous posts.
