Antz81
As my vehicles are sitting on a tall block of wood with steel shims on it the block of wood tilts in or out as shims are added or removed.
I thought you were supposed to make us feel more confident that your method was accurate and safe. But to me this doesn't sound safe.
I think LLC5 was referring to the questions about the grease zerks position relative to the wheel rather than the type of grease zerk.
You keep saying you have been doing it this way for 50 years, but how to you know that the alignment is right? If you have had it checked in a shop and it is correct then fine I'll believe you that it works.
Herniated oesophagus? That does not sound pleasant. Hopefully the procedure on the 15th goes well. (And lasts longer than the others.
