A
Ala75Vette
This past weekend, feeling motivated to fix my broken passenger side outer door handle (after getting confidence reading several previous posts), got the door apart and started tinkering. The inside door handle "did" work before, but I am now in the unenviable position of having the door, panel removed, shut, with neither door handle functioning (ala permanently shut door). So far I've been unable to figure out a way, easy or hard, of tripping the release mechanism to get the door open again, much less fixing the offending latching mechanism. Anyone have any ideas? Attached is a photo of the latching mechanism as seen through the window slot on the top of the door, with the plastic "splash guard" removed: 1- the trigger for the inside door handle. As seen from above, it rotates clockwise, with the finger on the left side striking 2- the "release" arm. This "finger" gets pushed by either the inside door handle or outside door handle to release the latch. Pushing it manually does me no good -- I can push it to its stop, and no release of latch. 3- is the post the door latches to. Help!
