Door outer seal strip
glomonac
New York
1987 Red Coupe
The outer seal strips on both doors are shot. When it rains my carpets get soaked. How hard is it to change them?
Thanks,
Guy
Do you mean the soft strip that presses against the OUTSIDE or the INSIDE of the window? Or some other thing entirely?
I had the OUTSIDE strips replaced on mine. Had the dealer do it because I don't have the tools or experience to mess around with door panels, drilling out rivets, etc. The INSIDE strips are screwed in and easier, or so I'm told.
I'm referring to the strip that's outside the window. It looks like I need to remove the window assembly to get to it but I'm not sure.
you dont need to remove the window, just the door panel, when you get that off it will make sense, when you get the new seals they should come with rivets, if not, just take the old one or use a drill bit to get the diameter and get some, you can use screws but rivets work alot better in this situation. Like I said, once you get in there it will make sense, I replaced both sides on the 89 I had and Im not a mechanic by no means.
Pulled both door panels off today. The back 18" is obscured by the window in the down position. There is no way for me to access the entire strip.
How did it look with the window up? I dont remember how I had the windows, it was a long time ago. I do know that I didnt have to take anything off other then the door panels and being real careful with the drill. I'll check the manuals when I leave work to make sure.
Just did my 88, easy fix, with the window down , 2 rivets are at the front, the rest slips into notches.
Torque Shop
Dream Giveaway
