CROOZ1N
Ok so Friday night I load up the Vette with the wife and the dogs to go to see my folks. They Live in Tazewell Va which is about 120 miles from here one way.
We are driving along just fine when we decide to pull off at one of our usual pit stops at about 75 miles from home. As I am slowing down and getting in the turning lane I hit a trench thats been cut across the highway. Its about 12 inches wide and a couple of inches deep. They cut the trench in the concrete then filled it back with asphalt. The asphalt I guess has deteriorated and left this 2 in deep trench. Any way once I hit the trench and coast across the highway into the parking lot of the store the car dies and I think Oh Crap!!
Well Oh Crap was the nicest thing I said for a while as she wouldnt refire. So we all take a pit stop and I just let her sit for about 10 minutes, She cranks fine but wont start. I get under the hood and look for loose connectors and such. No deal. I crank her again and she acts like she wants to start and finally does but idles like crap. I pull out on the highway and am able to get her on down the road but missing pretty badly.
We finally get to Tazewell and Stop at the grocery store where she dies again and this time won't refire. Thankfully I am now close enough that my folks come pick us up for the night.
Saturday morning comes and we go back to check on the car. Still no fire when we crank. I jumper out the a-B terminals on the adl connector and nothing but 12 comes up.
We can here the fuel pump kick on and feel the line pressurize and smell gas when cranking so we feel like the gas situation is ok. I pulled the coil wire and hooked up a wire to it so we can see if its firing. We got fire. I again look at all the connectors I can get to and find nothing. I even took the ECM loose and checked that I didnt jostle anything loose inside when I hit that bump. No good.
So we call a roll back and get her to a local garage where they only work 1/2 day on Saturday. The mechanic seems pretty knowledgeable and he basically goes over everything I've already done. He does hook up a fuel pressure guage and sees that there is about 42-45 ponds when the key is turned on. Then I think he said there was like 40 psi when cranking. He hooked up a light to one of the injectors and we could see it pulsing when cranking. He pulled a plug and we could see that it was firing and wasnt fouled out.
They hooked up their computer to it and got nothing either.
Now he seems to think that the anti theft may have it shut down. Is this plausible?
The security light on the dash does flash while cranking but I thought it did that anyway until she started as part of the lamp test.
They have another shop close by that has a box they can hook up to bypass the security feature that actually came from GM. They said they would get that and hook it up Tuesday.
I dont particularly trust that this is the problem.
So I have 2 questions. Does anyone know of a decent C4 mechanic between Tazewell Va and Roanoke Va?
If the security system is not the culprit where should I help direct these guys or do I just pull the plug and have it trailerd home?
I have a FSM and the tools to work on it here but its not here.
I am an electronics tech and work on automation equipment so I think I have pretty good troubleshoting skills. I was trained as an automotive/Diesel Mechanic before getting into electronics also.
Lastly If we have fire and fuel and of course air why wont she start( The mechanic even tried to get it to fire with ether and still no dice.
Thanks for all the advice!!
BTW its a 1993 LT1 117k miles opti and wp HAve been replaced but I'd have to check exactly when. Probably @100k or so. It was before I got the car.
