Droop Happens !
Missoura Ozarks
2012 💯 4LT GS Roadster
If we live long enough something on us will droop, but that's beside the point.
The Driver's door on my 96 Vette is beginning to show it's age, it hasn't drooped allot, but it is starting to droop/drag a bit. Wouldn't think it would happen @ 27K, but that's life.
I'd really appreciate it if I could get some suggestions as to the best way to adjust it.
Thanks In Advance,
6 Shooter
Michigan
96' LT4
Thanks In Advance,
6 Shooter
Really...already.........seems strange.............did you buy yours new?? Do you have a favorite body shop?? If not........I can ask mine...............he WILL know what needs to be done........if we go to mine ......I'll need some more detail and w/measurements and probably a photo.............you have my email.......get back.....and I'll catch up with him tomorrow before he goes north.........:bash :bash :bash :bash :bash :bash
Tallahassee, FL
none right now :(
I haven't heard of too many door problems with C4's... Does it look like it is drooping? where can you tell, or does it feel like it?
Missoura Ozarks
Very little droop/sag
It's nothing real visible, but u can see where it is rubbing a bit on the door striker/bolt. When u open the door, u can feel it droop/sag ever so slightly when it comes of the door striker/bolt.
Again, it's nothing major, I guess I'm just trying to say I'm a freaking perfectionist when it comes to my Vette :upthumbs
Tallahassee, FL
none right now :(
I have to look tonight... I know there is an adjustment for the doors, I just have to look again.
BTW, in case you didn't know, when C4's were built, the doors were put on, then the other body panels were lined up to the doors... there have been more than one instance of the doors being slightly off, and the whole rest of the car needs to be adjusted to fit to the door after the door is put in its proper place.
Missoura Ozarks
Ok, then I need to adjust my car . . .
Abingdon,MD
1996 Torch Red LT4
6Shooter, Your door is fine, the rest of your car is up too high! Just kidding. I don't know if you can adjust it. If not maybe a shim on the bottom hinge. Guy
NewGuy
Diamond Bar, CA, USA
1996 LT4 Collectors Edition
Also had a drooping door (is that a real word?).
Take it to any quality body shop. They have a tool that is a lift bar that locks into the locking mechanism and it is used to lift or drop the door once the hinge bolts are loosened. Should cost you very little and they do it right. Without the tool, you really need a strong helper to position the door after the bolts are backed off and you can possible scratch it if you loose your grip.
