jcoats
My lighter works (pops up and is hot), but non of my accessory plugs work in the lighter outlet. Are the lighter receptacles not compatible with accessory cords?
th
x
th
x
I don't think it's a dumb question at all. Although I can't speak to the question specifically in the C3, I have experienced the same issue at times with my C5 and it's usually because the device plug isn't a tight fit and prevents good contact. Does it work if you 'jiggle' the plug a bit? Another thing you may try is to "clean" the contact on the device plug by rubbing it with a clean pencil eraser.
No kidding; I used to have to do that to the contacts on my flash device for my camera. It gets a film on it that prevents contact and a pencil eraser is a simple fix to clean it.
Just a couple of suggestions until one of the C3 owners chimes in...
Jane Ann
