macx
Active member
Bought a decent running 81 several years ago, THEN found out the unique problems that can occur in the rear suspension and hubs/brakes.  Yup, I've got em!  I mean the problems.
I work away from home most of the time so the car has been sitting since I discovered that. Now, however, I'm doing some research on the engine to do a budget top end and cam upgrade with the goal of as good of gas mileage as I can get with mild and inexpensive mods, so I can take some longer trips after I retire in a few years, but still have some decent throttle response and power up to about low 5k rpm range.
I've got a 670cfm Holley Pro Jection TB efi I used on a small block van a number of years ago to replace a bad 4bbl and was amazed at the increase in gas mileage and lower rpm throttle response. Since then I've educated myself to a fair degree on efi, and have modified the efi in my daily driver with moderate upgrades, altho without getting into the ecu program itself. Sorry, not a Chevy tho.
Anyway, my current plans are a mildly mod'd 200-4R and 2200 lockup from Bowtie Overdrives and 3.31 gears (I have to rebuild the diff anyway) which, with 27" tires, will give me around 1600 rpm at 58 mph and 2200 rpm at 78 mph, so need good crisp low rpm torque and throttle response.
Budget dictates I leave the shortblock alone as it's in decent shape.
Currently looking at EQ Vortec style heads, 64cc chambers, 170cc runners, 1.94/1.5 valves, for about 9.1-1 compr ratio on the stock shortblock. They flow about 148 at 300 lift & 195 at 400 so should maintain good velocity for crisp low end throttle response. That's a little less than i.e. Dart or RHS vortec heads so should be a little crisper at low rpm. I'm concerned more about 3k or 3.5k and down than I am over 4k or 4.5k rpm. EQ's are easy on the budget at just over $300 ea assembled. They have more mat'l around the exhaust valve seat to eliminate the cracking potential and a better exhaust flow to improve on oem Vortec's marginal exhaust to intake flow ratio.
They're allowed and popular in IMCA claimer classes so must be of reasonable good quality and durability.
Thinking about 1 of 2 cams: Started out looking at the XE-262H but kept lowering my sights when I started looking at the rpm of the torque and the hp peaks, plugging in efi compatible. Finally arrived at the Comp XE-249H with 206/212 @ 050, 434/444 lift and with rpm range of 1k to 5k, per the Comp Camquest dyno program roughly 315 hp at 4500 peak, 400 peak tq at 3000, and 325 tq at 1600 which would fall right into my highway rpms. or Comp XE 256H-12 with 6 deg more duration and slightly more lift and with about the same hp and tq figures only the peaks are 500 rpm higher, rpm range 1.2 to 5.2k rpm, and tq at 1600 is about 15 less but still over 300, so either cam should really work quite well with my gearing. I don't want to rev my shortblock over 5200 or so cuz I need it to last, and this is mostly a cruiser vehicle anyway. Neither cam has much overlap which also helps lower rpm.
Now for the carb question. That TB efi setup will support about 325 hp with a 3 lb psi increase in fuel pressure from stock at the built in regulator and there's a closed loop setup available that would keep the mix correct at steady engine speeds like highway, and I've got an Innovate wide band I would use to help tune open loop. Either of those cams would fall within that hp maximum and of course efi is responsive and smooth with sharp throttle response at low rpms almost always more so than any carb.
BUT with this electric carb, properly set up with a little help (I've worked on QJets on stock 350's but they were 70's vehicles where you could adjust things like metering rod height and secondary opening etc) as this one is more complicated than a regular Q Jet
and I wasn't a huge expert on them to start with - any idea on the comparative throttle response and gas mileage from a properly set up carb versus efi? I also will likely go to a Performer type intake as I can't imagine the stocker is much of anything, esp given the heads it's made to match up with, except maybe a couple lbs more torque than a Performer right at the bottom. If I'd go with the efi, I'd go to a regular vac HEI as the ECM wouldn't function anyway.
If the carb would be pretty close to the low rpm throttle response and the smooth power of efi, with good gas mileage, I might keep it. But altho I've had lots of carb experience since I got into hot rodding in the mid 60's, I've never seen a carb that could hold a candle to efi at low rpm, either with response or smoothness or mileage, and I've already got the efi setup.
Thanks!
Appreciate factual info and/or tips from experience which it sounds like a couple of you guys have.
This is a couple years off, but I'm laid off right now so have time to research and plan.
Thanks!
