Wajulia
Hello all.
I am trying to tune my carb in after a rebuild. In general the car runs fine, idles fine, but not consistently. This is what I found out so far.
After the car is warm, start the car and the dwell reading goes to about 25. I have tried to adjust the idle air bleed -- I will discuss that a little later. The idle is good, but a little lumpy. After a minute or so, the dwell goes to 5 degrees and idle smooths out. Bringing the revs up the dwell goes up to about 30 then slowly goes back to about 5
When the idle is at 5, I can choke the carb and the dwell SLOWLY climbs up to about 50, where to my amazement, the idle smooths out again!!. removing the choke the dwell goes back to 5
Idle air bleed screw. I start that at 4.5 turns from the bottom. When the idle is at 25, i can turn it all the way to the bottom with no change in dwell. When turning it out to about 5 turns, the dwell goes to 5 degrees and does not react at all till I restart the engine.
The car also sometimes gets a code 44 (lean)
I realize this is a lot of data, but I am stumped as to where to go next? Any ideas?
