silver00v6camaro
Anyone here use this cam or something similar? do you like the cam, what heads are you using and intake and carb. Also if you have an automatic my car is th400 what stall are you using.
Here are the specs of the cam for reference.
Intake Duration 050 inch Lift: 234
Exhaust Duration 050 inch Lift: 244
Duration at 050 inch Lift: 234 int./244 exh.
Advertised Intake Duration: 308
Advertised Exhaust Duration: 318
Advertised Duration: 308 int./318 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.488
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.510
Valve Lift with Factory Rocker Arm Ratio: 0.488 int./0.510 exh. lift
Lobe Separation (degrees): 112
