- Thread starter
- #21
E
ecss
Geezz all that work to get back to where you started.
My recommendation is to get the proper wattage fog light bulbs and see what happens.
The circuit design is strange because the fog lamp bulb uses the Highbeam filament for its ground path.
The light circuit also turns off the Fog Lamp bulbs when the High beams are on by placing 12 volts on each side of the fog lamp bulbs.
If you do install a seperate ground for the Fog Lamps, you loose the ability of them being turned off when the high beams are on.
