My car has a code that comes up now and then "Charge system fault". I have been told it is a possible grounding problem, but it looks good around the battery. Car has 4000 miles. Now the radio (when turned on) starts a fairly heavy buzzing when the headlights are turned on and after shutting down the car, the radio will start buzzing again when the telescopic wheel goes in. Also, when I get on it lately and bring it to about 5ooo or so in first and then shift to second, the motor seems to want to cut out (or at least a quick drop in RPM) for a second or two as soon as I hit second ( RPM's around 3500 or so at that point). Kind of like a flat spot or something. All other gears and loads on the engine seem fine. Could this be my rev limiter coming in early on me? I have NEVER red-lined this car. The car has never displayed these problems before and I am wondering if they are all related to some kind of a ground problem. Could a grounding problem have an effect on the rev-limiter? The radio and the error message seem like a short somewhere, but could this also affect the engine under a higher RPM load? Also, with the exception of the battery area, I'm not sure where to look for obvious grounding points. Any help would be most appreciated.
