- Joined
- Oct 31, 2003
- Messages
- 133
- Location
- Rhode Island
- Corvette
- 1984 Black Coupe (sold) 1992 White Convertible
I'm not too sure whats going on, but my interior lights used to come on when I opened my doors, but now they do not. When I pop the hatch, the lights in the back come on. I think this problem happened after I had installed my aftermarket radio, but not too sure if thats exactly when. Either way, it also used to blow a fuse whenever I manually turned on the interior lights with the headlight knob. This started happening after the radio install. And now, tonight I pulled the radio out and wanted to see if that made any difference. The only difference now is that instead of blowing a fuse when I manually turn on the interior lights, it starts smoking behind the dash near the headlight switch. LOTS OF SMOKE.
Also, when the lights are on they are very dim. If i push the map lights on the doors on they go on fine and are bright. Has anyone had this problem before??
ad I've already removed some of the screws but am debating whether to even bother. The fuse doesn't blow and the switch doesn't smoke if I don't try to manually turn on the interior lamps. The only drawback is i won't have interior lights when I open my doors. I can only use the maplights.
