F
Fiddler's Gold
Everyone,
I have been out of town for quite some time, unexpectedly.
Background:
Dash seems to function ok. Fuel, Batt Voltage work but everything else is non-responsive. I do get some kind of "guesstimation" from the RANGE button but I don't know if that is accurate or not. Everything thing is lit up and appears to be capable of working.
TACH:
I come back and I am still faced with the same electronic TACH/SPEEDO not working issues. I have searched the archives and have been researching this issue heavily. I have a GM style HEI with TACH connector for the feed. What pin on the dash should this be conencting to? Is it ok to run this wire directly with no tach filter inline? Could I split the tach send wire to both the manual tach with shift light and the electronic tach at the same time?
SPEEDO:
I have a replacement T56 :crazy (from late model Camaro) which I was told uses different VSS pulses than the 4+3 etc for the ECM and dash. Will the SGI-5 box from Dakota help in the conversion to the dash to get it to function? What type of other adjustments need to be made to the speedometer and what is the pinout/connectors for the speedo for the dash? Any help would be greatly appreciated. I think I am going to have a problem with the PO not hooking up the connections at the tranny and we will need to see if this is even possible at this point. I don't want to have to tear apart the tranny to get to the speed sending components. I think there is a wiring set leaving the tranny - lets hope that it is not melted or busted up. What would the proper VSS send wires look like?
Thanks so much for any/all help!
Andy
Background:
TACH:
SPEEDO:
Andy
