M
Medicash
Hiya, I was wondering if i could pick your brains, I have a 1977 C3 corvette with a smokey engine (numbers matching)now the choice is do I spend money on a rebuild, or do I buy a rebuilt LT1 Small block with the following
LT1 block
4 bolt main bearing crank
Big journal Crank
Full engine balance inc flywheel and new clutch
Heads ported standard valves
268 competion cam hydraulic lifters
Roller valve gear
Torker 2 inlet manifold
Holly 750cfm carb vaccum secondary
4 branch s/s headers
Mallory duel port distributer
Edlebrock high clearance rocker covers
High volume high pressure oil pump
Steel duplex timing chain and gears
Chrome sump
Chrome timing case
Short water pump
Aluminium belt pulleys
Chrome air cleaner
This engine also comes with these spares
2 big valve heads not ported
1 pair of moroso rocker covers
Spare carb
Low mileage cam followers and gear
It has never been run since its rebuild.
now I know nothing about engines so I don't know if the LT1 has all the bits to make a fab engine,or what the power output would be or the fuel consumpsion would be, the LT1 is for sell for £2,000 in the UK, your thoughts would be very much appreciated.
many thanks in advance
Jerry
LT1 block
Big journal Crank
Roller valve gear
Chrome sump
Chrome timing case
Short water pump
Chrome air cleaner
Spare carb
Jerry
