Engine Combo
770 too much carb......back down to a 650.....shell respond better and you wont have to use such small jets...
Hey Silver, your combo looks fine. One question about the intake is this the single plane or dual plane. A single plane has one large opening and the dual has the opening seperated. The dual plane helps build the power lower in the rpm range (1500 to 5500). This makes for a better street cruiser. The single plane builds the power later (3500 to 7000 rpms).
Good luck. peace Bud :w
Hey Silver, should be good to go. I'm sure you will feel the increase in performance. Aftermarket heads and headers/exhaust always help too.
peace Bud
What about using the upgraded vortec heads from sdpc with this combo instead of the trick flow heads. Would i still see good results.
