B
blueslady
hi i have a 1984 corvette. the antifreeze is in the engine compartment. it was running hot at 260... then the hood wouldnt open. found out the cable had snapped.. What should i do? have a mechanic take the head off, and see if the gasket is no good, and then send the cylinders out to be checked? Thanks Blueslady. And yes the car came with the engine........
