paz72vette
how hard is it to pull the nose off a vette? I used to do this on the chevelles and malibu's and it was not hard at all. I have a 72 vette that I am going to work on this winter.
paz
paz
paz
thanks, this will be my off season project.The Corvette body is many panels, all bonded together into one piece. To get the nose off, you have to split/separate the bond joints all the way around the cowl; the front end isn't bolted on like it is on a steel car.
Unless I missed it above somewhere, are you planning on rebuilding your existing engine? Any idea what kind of condition it's in? Do you plan on sending in the block and having it magnafluxed? No point in building a hi-perf engine from a questionable base.The motor is getting older, and Im ready to start from scratch. Im not sure what is in there now, other than its a non-original 350 that was dressed up to look like the L82 that should have been in there. As for my plans, Im planning on doing a 383 somewhere around 450hp/tq.
No need to replace your cooling system unless you are sure you need to. Yes, pulling the radiator is easier when the engine isn't in the car, but that applies to pretty much everything under the hood. Replacing the radiator at a later time isn't hard.For the kind of power Im looking to run how well do you think the stock cooling system perform? I was thinking I may have to go to electric fans.
Determine right now if you want a manual or an automagic trans. If you really want a manual, then save up for it. Otherwise, either -R4 trans will work when properly beefed up. If you already have a 3.70 rear, I'd suggest the 200R4. The 700R4 will likely give you too much torque in first gear since it has a more aggressive first gear than the 200R4. What good is all the power if you can't get the car off the line due to no traction? Also, the 700R4 is going to require additional mods whereas the 200R4 is supposed to be plug-n-play. (I've seen one person in the forum say "no it's not" while everyone else has said "yes".How much power do you think the stock driveline can take. I currently have a rebuilt TH350, which Ill probably end up replacing with either a 700R4 or a TKO600. I have a 2yr old rear end with 3.70s as well.
Do your own research. Bowtie would be a good start. I have a BTO 700R4 in my car...wish now that I had saved for a TKO.) If you are sticking with an automagic, be sure to match your converters stall speed to the "normal driving" RPM that your engine will see most of the time. For a stout engine on the street, somewhere between 2000-2400 should do ya well. If you are primarily drag racing, then obviously you'll want something higher.
My Level 3 blew up sometime after the 12-month warranty had passed. Front pump detonated. They said that it would only blow up if it wasn't installed correctly. I'd bet my life that my install was perfect. Nonetheless, $1400 later and I had my trans working again. To say I was mildly pi$$ed off would be keeping it civil. If I had known I'd be putting another $1400 into it, I would've done a conversion to a manual trans. Yeah, I wouldn't buy one from them either, but I know people that have had great experiences with them. "Your mileage may vary."![]()
If I were you, I would steer far away from Bowtie Overdrives. bought one of their stage 2 units with a 2500 stall converter and it only made it 15000 miles before it went to sh*t!!! The converter came apart and took the trans with it. When we got it apart, we found that the sprag showed in excess of 100,000 miles of wear, the servo was for a truck and the clutches were just about as low perf. as you can buy. In short---it was a piece of crap. The shift points were never good and solid. (Yes, I had the TV cable set up correctly).
I've pointed people in their direction in the past... but I'm not so sure anymore.
erd:
