B
BTWard454
Because of damage done to my 81 proir to my owning, and a little I have contributed myself, I decided to put an entire new front clip on my Vette, along with side and rear ground effects. While I had the front end off, I figured it was also a good time to swap engine, since the old 350 was getting a little tired, so I bought and built a 454, and its around 530+ horsepower.....anyways, I've got the engine in, and it runs great, but of course none of the computer harnesses are compatable anymore. So my questions are 1) Could the computer being unhooked be the cause of my oil pressure gauge not working. I've tried a new gauge, along with a new sending unit, and also tested the power on all the wires, which all seem fine...2) If the computer is not the cause behind all this, since everything else is working, will it affect any other systems if I completely remove all the computer wiring harnesses and the computer too, because they're all just dead weight now. Any help would be appreciated.
Brent
Brent
