H
Hijinx
Have all the EPC (Early Performance Christmas) stuff in the garage, and the old exhaust removed. I'm ready to roll - but wait - figure I need that good old advice I always get here.
For those of you that did not read my earlier EPC post (shame on you), I just bought Hooker ceramic coated equal length headers, an MSD billet tach drive distributer and 6AL and have started the install.
While I am doing this install I plan to remove the charcoal/vapor canister (disconnected since the Demon install). My thoughts were to install it in the back next to the gas tank to take care of the vapor line coming out of the top of the gas tank. Any thoughts here?
What other things should I do while doing all of this? I will put the heat boots on the plug wires, that one I have covered. I may go ahead and replace the fuel pump while the compressor is out of the way and run braided line to it (blue Aeroequip today). I also have removed the center cross member and will sandblast it and a few small parts and either paint or powdercoat.
What else should I consider doing while I have it high up on jack stands and partially taken down?
