I have a 1970 LT-1. I was a californis car so I believe it had A.I.R.. The fan belt pulley plate on the water pump only has two groves with one belt going for the Crank / water pump, and the other for the crank, water pump and alternator.
questions:
1. Did all LT-1 s come with AIR
2.How do you adjust the tension on a belt going only between the water pump and crank pulleys?
questions:
