The73vetteman
If we could keep the discussion to the technical, that would be nice.
If you think about the combustion process I'm really not sure how much difference the brand of plugs used can make. All you're trying to do is generate a spark of sufficient temperature to ignite the mixture. Providing you've got sufficient voltage to ionize the gap and sharp corners on the electrodes for charge concentration, then ignition will happen.
'73
Regarding iridium tipped electrodes, my understanding is that the main benefit these confer is no electrode wear, i.e. longer life. In that sense they're similar to platinum tipped electrodes.Larry82 said:Why would you run anything but Iridiums spark plugs?
'73
