6
69vettester
Ive been putting off posting this problem until I got time to go about fixing it. Im also rea dumb in this area. I dont think I need to post a pic of the problem, but will if anyone needs to see it!
The area is on the back lid that opens and closes my ragtop compartment.
The drivers side area where the open close mechanism mounts was evidently abused at some point and the fiberglas is crushed and mushy. Its getting worse as I continue to put the top up and down(duh). Its getting increasingly harder to get this side to unlatch and also to close up again. I have to do this special little "hold on the mechanism" and pull the latch procedure Ive got some small ideas on how to get the fiberglass back to solid around the mechanism mount, but really need full details on the whole procedure. Im hoping this problem is no big deal to many of you guys, but to me its unknown territory and Ill blow it for sure before getting it right :cry ,
Can anyone map me out a good way to go about getting the situation back to normal?
Thanks in advance..
TomC
PS...Im real reluctant to open the lid? panel?, again until Im all set to fix it right then!
Thanks in advance..
TomC
