fixing trunk relay issues in a 82
topless82vette
southern california
1982 convertible (not factory) stock 350cfi auto
Previous owner rewire my relays using solderless connectors and what appears to be bosch type headlight relays ..... I want to try and convert them to GM weatherpack realays ... Is this possible and what specific pigtail would get the job done? Fuelpump relay/fan relay/ etc.
Last but not least what wire color would go to what terminals on the weatherpack relays?
Anyone who has done this please post what exactly you did.
The best thing to do is determine what the input and output connections are on the new relays and match the funtions to the exsisting harness. It will take some research on the new relays to do it.
The electrical diagrams can be found here.
http://misterbill.homeip.net/vette/wiring/ECM_fuel%20and%20idle%20control.jpg
The relays have two connectons that are input activation for the relay, and 3 output connections(1 common, 1 normally open, 1 normally closed).
You have to match up the connections from the original relays to the new ones.
