Rodney Gold
- Joined
- Jul 28, 2003
- Messages
- 200
- Location
- South Africa
- Corvette
- 1986 White l98 coupe, 1995 LT1 coupe
My vette has lost some camshaft lobes and a few lifters after just 1600 miles .1 yrs use.....started running rough, valve train noisy , getting too hot and oil pressure at hot wasnt so good .....
Comp cams 270h+ lifters , assembly and break in was meticulous. Only thing I didnt do was use comp cams break in additive when breaking it in and used the stock oil in the motor at the time (was just a top end rebuild).
I have seen many new cams exhibit this type of failure recently .... and many v8 engine builders here are experiencing it as well.
It seems to be a combo of inferior parts and "bad greener" oil...
So with the new cam (same grind) I am using the break in additive as well as Rotella oil as well as using the comp cams additive on a constant basis.
I dont feel to pay for roller lifters and a roller cam as parts here in SA are very expensive with freight and duties ... apart from which , money is a little tight what with the credit crunch
