vms4evr
Hey folks,
I appear to have a fluid leak but for the life of me I can't find it. And all my fluid levels are good! Oil, trans, cooling, p.s., brakes are all at the full level.
A couple of months ago I replaced my rear gear fluids (a messy job). And some did get on the exhaust pipes right before where they split off in a Y to the mufflers.
There is some oily mess on the top of the exhaust pipes, the very back end of the driveshaft, and the bottom of the compartment that houses the ASR computer.
I wiped it off and it looks and feels like brake fluid. Oily, light brown, not very strong smell. But my brakes work just fine.
I put engine cleaner and degreaser on everything, scrubbed it down with a scoth bright pad and then hosed it off. Not perfect but much cleaner.
Looked all over the back end and followed brake lines, gas lines, etc... and none appear to be wet or leaking. I also double checked the gasket around the rear axle and it is not leaking.
Am I freeking out or is there something else I should be looking for to try and hunt this down?
Graham
Graham
