Vette79
What's wrong with this Picture???
hnoes Took her out for a cruise and decided to open her up and then a noise, lack of power and running/idling rough. Limped home and let her sit for a couple of weeks. After working most of the week on installing new center cluster trim and center console trim and related pieces/parts, we finally got around to troubleshooting it. We started with removal of the plugs and found a light coat of oil on #1 spark plug. We were able to get spark at all cylinders. We were going to do a leak down check, removed the drivers side valve cover and "Whoaahhh". Broken rocker arm stud. The rocker arm had a bluish tint which means it obviously got very hot which led to the stud being stressed and snapping.
In any case, we removed all of the rockers and rocker studs. We are upgrading to 1.6 roller rockers and big block rocker studs. The pushrods are fine. Guess what I'm getting for Christmas???
