chevyaddict
Hi all;
I've searched the threads but can't find an answer to this hypothesis I have. I'm working on the 68. Car tracks fine, is smooth, no problems UNTIL I hit a bump or rough spot in the road. When this happens, the whole front end shakes BAD! Have brand new tires and are balanced fine. Again, on a smooth road everything feels tight. The wheel bearings are fine. Now, the control valve leaks so I have the system dry right now. However, I don't think it being dry is making this happen as the 81 had a leaky system and I drove it awhile with no ps fluid and didn't have this phenomena.
So, my hypothesis is that the cylinder is no longer functioning... in other words the seals inside are broke and allowing extra movement in the system when there is a perturbance. DO YOU GUYS CONCUR? The rest of the front end isn't perfect but isn't bad. There isn't anything obvious or loose as far as balljoints, tie rods,etc. Front end feels pretty tight otherwise.
Thanks!
Thanks!
