Fuel Line Removal
Emtmike
OH
1981 Biege & Dark Bronze Coupe
I figure since the vette is up in the air, I wanted to change my fuel line from the pump to the carb :). I've tried to remove it from the carb with no luck, but was able to loosen the bolt at the pump :). It seems that I'm getting way to much gas coming from it and was wondering about how much is going to drain out :eek:hnoes. I've changed fuel filters before with less gas draining out....anybody got the answer? ;shrug
Since the tank is higher than the fuel pump, it will drain the tank dry.
Gary
Gary
Thanks Gary.....I wondered if that was the problem. I even dropped the rear down to the ground and it still was draining. I did finally get the top loose and changed the filter :cool. Thanks for the info :thumb
