Any ideas?
After driving until the engine is good and warm, if I leave it shut down for a half-hour or so, it seems to load up with fuel.
Holding the accelerator to the floor usually gets me going after a few cranks, but the smell of fuel and the puff of blue out of the sidepipes is nasty.
I've also noticed a more pronounced smell of gas in the garage after a cruise.
I've checked for leaks, and there appear to be none. Fuelie was over yesterday, and had a look at a few things (two heads better than one). Nothing obvious springs to mind. There's no purcolating down the butterflies after shutdown either.
The float levels are right too. :confused
I found a temporary preventative cure, however. If I turn off the electric fuel pump about 30 seconds prior to shut down, the problem goes away at re-start. Since this pretty much empties the bowls, it would seem to suggest that the fuel is cooking in the bowls after shut down.
One more thing. Once the engine is good and warm, I occasionally get a notceable but very brief engine-stumble when turning a hard corner in either direction.
502 c.i. / Holley 850 with electric choke
Any ideas?
Any ideas?
