Peer81
Put enough cloth around the yokes inside the diff so the metal and get to your bearings. If the yokes are out you can remove the case and then it is much easier to remove the center shaft. All the shims are between the case and the bearings pressed on them so there is no way you can loose one or get it wrong.
Greetings Peter
Greetings Peter
