G
Gerry
Hi,
I finally received my engine from Shafiroff and it looks beautiful, I will post pics later. I have a few questions and I hope someone can provide answers.
What is the fuel line size from the pickup in the gas tank to the motor?
The car is a 67 427/390 all original. Is it 3/8" or what?
Will the original line be big enough for a 540 CI 675 HP motor?
Does anyone make a Aluminum flywheel with steel or carbon fiber insert (must be for internally balanced motor) and has anyone used this kind of flywheel with this type car/engine. The trans is a Keisler TKO 600 5 spd. with Sachs HP clutch supposed to be good for 650 HP.
Would the use of a Lakewood scatter shield be necessary or just a good idea?
The car will be limited to possibly 8 inch wheels with street/strip drag radials no bigger than 255 x 50 or 60 x 15. I know this will be the limiting factor to getting the power to the ground. I have a Be Cool Aluminum rad with 3350 CFM elec fan, Stewart high flow waterpump, driveshaft loop, halfshaft loops, 420 lb monospring, heavy duty diff cover, racing camber struts, HD offset trailing arms, Aluminum rear mount frame bushings, polygraphite bushings everywhere, 550 lb/inch front springs, and will have a full 6 link susp soon.
Is there anything else that would help?
Thanks for all the help so far and I still hope to have this ready for Carlisle.
Best regards,
Gerry
Best regards,
Gerry
