A
acmsal
Took my 1978 (L48/auto,completely stock) Silver.Ann. to be smogged. It
failed, bad egr valve the mechanic said. And, the timing mark at the
crank
was floating all over the place. Took it home and tried to check the
timing
but 6 degree mark kept moving all around. What would cause this? Took
off
the cap and rotor, look worn and tired, will replace. But should I also
replace coil and module inside dist? Plugs and wires are new. Took off
egr
valve and the rubber diaphram looks worn, will replace. Help, what's up
with the timing? Oh, by the way the car runs fine, only hesitates
slightly
when cold.
crank
timing
off
egr
slightly
when cold.
:L
