SPANISHVETTS
- Joined
- Nov 5, 2002
- Messages
- 1,143
- Location
- El puerto de Santa Maria Spain
- Corvette
- before 60,63&82 now 90 383 Stroker & 91 ZR1-Sold
Thunder is making me nuts…Help!
Runs great when cold. When hot stalls when you accelerate from idle or low speed, backfires in exhaust and intake. After sputtering for a bit it will run at 2000RPMs or more but not good.
Changed: fuel and air filters
Checked fuel pressure: 40 – 44 lbs.
Checked injectors resistance: all within tolerance.(Could they fail when hot and test ok by the time I can disconnect and test them?)
Swapped distributor with a known good unit. New plugs and plug wires.(old plugs were clean and brown, looked a bit lean but not bad)
Chassed all of the ground wires – can’t find a bad one.
Compression appears OK. I only have a static gauge so can’t test bleed down. Engine has 18 K on serious 383 build – uses no oil.
Checked for gasket leaks and checked the coolant for exhaust gas. Everything looks OK.
Bought an AutoXray 6000 scanner because the team does not have an OBDI module for the SnapOn.
Here is what it caught during 10 seconds while Thunder was spitting and backfiring.
Time.... 0 ....+1sec.. +2sec.. +3sec.. +4sec.. +5sec . +6sec . +7sec . +8sec . +9sec
RPM. .1028... 813..... 894..... 1148..... 1238..... 882..... 811. . . 1233. . . 864... 1028
TPS.. 1.17V. 1.17V ..1.17V.. 1.25V.... 1.37V.. 1.37V .. 1.35V .. 1.70V . 1.70V . 1.72V
Speed 0MPH. 0MPH.. 0MPH... 0MPH... 2MPH... 2MPH. . 3MPH . 2MPH . . 2MPH. 2MPH
O2... . 28mV .20mV.. 24mV.. 32mV. . 24mV.. 20mV . 24mV. . 32mV . . 24mV 28mV
MAP. . 3.52V .4.05V.. 3.70V.. 3.66V. . 3.99V.. 4.25V . 4.33V .. 4.48V . . 4.66V 4.60V
IPW* 4.5mS 6.1mS.. 4.6mS. 4.9mS.. 5.2ms. 5.9mS . 5.6mS . 6.0nS . . 6.2mS 6.5mS
RLF*.. Lean. .Lean... Lean. ...Lean. . .Lean.... Lean. . Lean . . Lean. . . Lean.. Lean
Loop Closed. Closed .Closed. Closed. Closed. Closed. Closed . Closed . Closed Closed
*IPW injector pulse width
*RLF rich lean flag
After pulling my hair out I am down to fuel pump or injectors. The injectors are bosh 28# with 18K miles and the fuel pressure looks OK. The injectors rattle like they are firing so I have ruled out the quad drivers.
WHAT HAVE I MISSED?
*RLF rich lean flag
WHAT HAVE I MISSED?
ad
