calwldlife
high 81 experts
I have been chasing a problem that has gotten so bad the car is undrivable.
When doing a system check carb dwell fixed at 20
Had a code 23 M/C sol
chased wires, sensors, and ECU.
Only part that is flacky is the TPS. maybe.
Solenoid clicks like it should. It Ohms at 23.1
I can not figure it out.
at part throttle it has set the 23 code, dwell starts bouncing from 50 to
10?
Mainly it does not set a code and has a fixed dwell of 20.
Air bleed does not change it.
HELP
10?
HELP
