Rookie Vette owner
Finally got all the interior out of my 73 to track down the source of my leaks. The biggest ones I have found are the floor vents from the cowl area. When water goes into the wiper/cowl area, it flows directly into the floorboard from the vents on both sides. I have reviewed the assembly manual and can find no indication of drains for the vents and vacuumed the areas of all debris. could someone please confirm my belief that there are drains in the area, then I can dive in tomorrow and try to locate them and hopefully figure out how to unplug them. Also I have replaced my weatherstrip around the windows, doors, and T-tops, but have not reinstalled the door panels. Should I expect to have water still getting into the car since the weather barrier that goes under the door panel is not in place and the sill plates (also removed) are not directing the water out when it gets to the bottom of the door? :confused
Thanks!
Thanks!
