jotto
Im starting work on the engine to get her running smoothly but need some help as Im a little unsure where to start if Im honest.
She starts and runs but as soon as I give her any acceleration she dies. I checked that there was a good flow from the accelerator pump which there appears to be so I think it would be best for me to start at the beginning so all tips greatly appreciated.
I did find a post by wajulia that had a long description of what to check and how but for the life of me I cant find it now.
Some info for you to help me.
Air pump is on but disconnected as diverter valve was badly burnt.
3 air pipes blanked off at manifold check valves.
There appears to be one open port at the front of the carb. I believe it is a T pipe with one hose going to the choke pull off and the other port open. When blocked off, it runs worse, when open, it runs better. It seems like it is running too rich and needs more air. Does this connect to the air cleaner when fitted?
Before I tear in to the carb, what should I check.
Is there any online guides to tuning these E4ME carbs as well as checking computer is working correctly.
Also, one quick question, should my choke light stay on whilst the choke is energised? Mine comes on when key is turned to on position but goes out when engine running even though choke appears to work.
Really do appreciate any help.
