S
schmaltzr
I recently had to replace the drivers side window switch with a new one. I realized that the switch was the wrong one becuase it didn't have the memory option on it. I bought the right switch, disconnecting the battery once again and installed it. The switch works fine. My keyless entry FOB has to keep being re-set using the lock/unlock method. I even did the DIC re-training method. The FOB works for a little while and then won't work. I've replaced the battery, it does the same thing. No DIC messages are displayed. - Ron
