RONALD50
HI IM GETTING THIS CODE I JUST HAD A TRANSMISSION PUT IN FROM AAMCO CAN SOMEONE TELL ME HOW TO FIX THIS PROBLEM THANX
yes i own a 1998 coupe automatic thanx for helping me aamco charged me 2800 for trans and they gave it back to like this with that code what you suggest i do take it back right your saying when they put trans in they messed up the wiring is that right did they have to mess with any wires to put trans in im mad 2800 alot to me ok thanx for trying to help me ok bye ronHI there,
Is there a module bolted to the rear subframe????It will look like a box with about 6 brake lines coming in and out of it.
If there is, the wire I am speaking of travels up over the differential and down the torque tube to the PCM, located at the right front wheel.
Thats why I believe that it is pinched.
Allthebest, c4c5
